Potterton EP2002 Replacement
7 Jan 2013
Sussex
I have a Potterton EP2002 Programmer. I would like to replace it for a unit that has a wireless Room stat. Is there a replacement anyone can suggest that would require no major rewiring i.e just replace the front of the unit?
There is none that will fit on that back plate other than the ep range.
If that is the case is there a model that would require minimal rewiring that would also fit my requirements?
A clear pic showing the coonecting wires would help.
They more than likely used the prog as a wiring center so could be quite a bit of work.
Ok I will try and get a pic and post it. I had in mind something like Horstmann CentaurPlus ZW just not sure if its going to be too big a job.
