Hi everyone.
I have a problem with my potterton flamingo 40 boiler.
2 tanks in loft, cylinder upstairs next to pump and control valve, boiler mounted downstairs.
Every morning the boiler pilot light is out. I manage to relight it eventually. Difficult at first when boiler is cold as it keeps switching off after a few mins. Eventually after maybe 6 restarts over course of 2 hours it stays on for longer and longer between restarts and will last for entire day until whole procedure is repeated the next day.
Bleed all radiators each morning, no air. there is a little air in the pump each morning which i bleed but my question is this;
As it seems to be easier to keep the pilot lit as the boiler itself gets warmer, would this point to a thermostat problem, or thermocouple problem?
I read somewhere in this forum that it could be an overheat stat too but after looking at the manual i can't find where this would be. is it inside the thermostat assembly itself?
Thanks in advance.
Graham.
Thanks in advance.
Graham.
