Something doesn't seem right.
The boiler operates between 55-82 degrees so measuring 59 with the stat half way is wrong.
Also if the flow temp is only 59 even with NO FLOW would the heat build up to 90+ and trip the OH stat.
If the system works and boiler doesn't cycle at all when heating rads then I doubt you have a circulation fault.
When I work on any of these boilers the stat gets left between 2-3 with a flow temp of around 70.
Check the pump overrun is working the I think you should get someone in before wasting more of your time and money on **** like boiler buddys!!
