my boiler wont come on ,the pump runs but i cant hear the fan running,been
through the check list in the handbook got 240 @swl and n, got 240 @t6 & t2 on the ecu, next step i need to do is test the fan how can i do this ?.
Don't remove the case, this is a positive pressure boiler.
The fan supply is the 2 red wires coming off the PCB, far right as you lock at it. If you have power here it suggests a faulty fan. If not look at the air pressure switch before assuming the PCB.
i have checked and i have 240v between the two red terminals, i have the gas of and i have the fan out , on the fan terminals what should i test for continuity or will there be some resistance reading.
i've now got the fan working, replaced it and the boiler cover but it still wont fire up,checked the pressure switch and if i blow gently into the red flexi pipe the boiler ignites ok, i cant feel any air coming out of the two flexi pipes, should i be able to
ok lightning point taken but i already had the case and fan out before i got your warning. i know it maybe against your rules but could you give me some indication what you think is wrong ,its been working fine now but only if i leave the clear bottom pipe with the restrictor disconnected from the
pressure switch.
