Potterton Suprima HE 50
30 Dec 2008
Kent
These new Suprimas (the condensing version) don't suffer from the same problem as before, do they, i.e. PCB failure etc...?
thanks
thanks. I see the current PCB is right up against the bottom of the boiler (with burner right above it) so i did wonder.
you would hope Potterton would have fixed it after all the media attention with the first ones, but i would never be surprised....
just make sure the compression joints that conect to the flow and return don't weep as they are still prone to rotting through the casing.
