Potterton Suprima lock out problem - overheat stat?
19 Jan 2005
Hi there
Hope someone can help!
Power was switched off to the boiler today and at switch on, it wouldn't re-ignite. Pressing the reset button resulted in unsuccessful tries then then 'lock out'. I read in the literature that switching off the power could result in the overheat stat operating - so I'm guessing that it might be this. Is there an easy way to re-set it? Can this be done by a sparks or does it need to be gas safe?
The boiler was pretty cold when I tried to restart as it had been off all day
SB
New circuit board......
Poxi Batterton electronics again. Did you do an insulation resistance test?
I'm assuming you are a sparks? If the polarity was reversed to the boiler you would get precisely the problem you describe......
Thanks Simon
BTW I should have mentioned it's not my boiler!
Do you mean IR test on boiler??? No. But I IR tested the circuit with the boiler isolated.
Customer moved in just before Christmas and # mentioned that they had had to reset it once or twice.
Is there a way to check the overheat thermostat first, before getting PCB replaced? I gather they ain't cheap...
