Power Flushing
B
Bodd
Hello All
I have a customer that needs a power flush. Problem is he has a septic tank. Its a big system so lots of chemical.
How can I get rid of the chemical in a safe manner. Or how can I go about it in a diffrent way?
Bodd
I suppose you could store the waste water and nuturlise it, so it has the correct PH etc?
Use a less reactive checmical x800?
Not something i have come across.
Apparantly even fresh water would upset the PH factor on a septic. Would like to leave well alone> But been a customer for some tme.
Thanks Sting
Use Fernox DS-40 and then the Neutraliser before you drain it, IIRC the neutraliser makes it safe enough to drain onto the ground, thereby avoiding the septic tank issue
Thank Muggle I'll look into that
Most products are biodegradable, so should be no problem. Ask the manufacturer if you want to be sure
we had to get a bowser in once to ferry the waste water away on one like this :)
Citric acid ( DS40 ) is relatively harmless and can be tipped to drain in the garden. More relevant is the copper salts it produces when it dissolves the sludge.
Those copper salts will kill the bacteria in the septic tank.
However, if you dont add too much acid there is very little left to be tipped into the garden but just not near fancy plants.
Tony
He has a large gravel drive if I used a lot of netraulise and spread the waiste about drive?
Or do I just mains flush it? I'm putting new valves on rads and a magnaclean on so I could do that and use the hammer drill attachment. To create a little havoc.
Just some feed back on what I did in the end.
It was a damed if I did and damd if I did'nt.
I powerflushed without using a chemical. Never really circulated much. I just dumped and pelted the rads with hammer drill on chisel with attachment.
Cleaned pump out manually and changed valves wear nesserary, and installed a Magnaclean
Great result apart from 2 rads out of 20. Better by 50%. The two not getting hot need addressing.
But over all every one is happy. Customer could be happier with the Bill but can't have it all.
Thanks all for advice
Bod
