Premier Elite 28 w Door Impact Sensor
7 Dec 2014
Hi
I have one of the above installed on the entry exit route and have the following problems.
Ricochet monitor shows it as be ok.
It wont chime when the door opens
It wont trip when doing walk test.
I have tested using Engineer Utilities, View zone status , the secure status remains even when the door is opened.
Can anyone please suggest a solution.
Thank you
what zone is it learnt to?
what is that zone programmed as?
the chime attribute is assigned in zone attributes for the zone
Then you can turn chime on or off at the keypad by pressing the chime button.
lol 12,24,48,88,168,640, but the 12 will do 16 zones I believe just to confuse things.
If the status isnt changing check the reed disable pins arent shorted.
The programing will check that its set up to chime.
Wot a plonker - I feel so stupid.
It was the link disabling the reed that I had put in the wrong position.
Thank you all very much. I really do appreciate the help and support.
