I’m currently redecorating our dining room and was hoping for some advice about prepping a couple of walls prior to decorating.
Wall 1
Had a previously poorly patched area (of redundant electrical chases/sockets) hacked back, PVA’d, bonded and skimmed with thistle multifinish by a plasterer, who also skimmed the rest of wall at same time. The plaster is currently 10 days old. Will do two 1:1 dulux trade supermatt mist coats soon (plasterers’ advice). After this will it be ok to use a finish coat of dulux light and space (particularly dark room) or should I give it a couple of neat coats of supermatt and then finish with the light and space in a few months?
Wall 2
Lime plaster (in pretty good nick but with filler aplenty) except one new replacement patch (about 20x25cm) with bonding down to the brickwork (maybe 1cm deep?) and multifinish on top. The older plaster was previously wallpapered and although most of the paste has been cleaned off, some probably remains. The patch is down by the skirting board where it original looks to have been covering the sealed off end of an old lead pipe. The pipe wasn’t chased into the brick work.
My plan for this (as with walls 3 and 4) was to seal the whole wall with Zinsser Gardz to inactivate the paste and protect old plaster/filler medley then put up lining paper and paint. However, I’ve since considered whether this might be inappropriate for the drying of the new patch since there is the small area of bonding plaster. If I want to be sympathetic, should I Gardz the old plaster to seal off the paste and mist coat the patch with supermatt, then neat supermatt the whole wall and paper in a few months’ time? I don’t know how good that wall will look just painted, but will probably look better with lining paper.
Sorry if a bit rambling. Figured more info would be better!
Cheers.
Wall 1
Wall 2
Cheers.
