Hello - some advice please...
Have a failing (leaking) primatic cylinder which i would like to change to an indirect so i can fernox the heating side. There is a back boiler, and the pump is under the floorboards next to it.
my main question is: where do I make the connections from the F& E (which i need to put in) cistern to the flow and return? Can they be where the flow and return go into the cylinder, and if so specifically which (feed/ vent) to which (flow/ return)? ...I'm hoping for a 'yes'!
Cylinder is in a cupboard on the landing, not much room to play with...
Thank you in anticipation
