Problem with Viessmann 100w and vitorol 100 uta rf1
19 Aug 2013
Bedfordshire
Hi There,
Ive recently had the Viessmann 100w boiler fitted and got the vitorol 100 room stat yesterday. I cant seem to get the heating to fire up through the unit, ive setup the room stat to the paperwork and im getting good signal strength and as i adjust the stat I get both the heating and hot water lights come on the plug in unit. Ive also taken the jumper out of 1 and L, if anyone could help me, im getting hot fine thru the taps, ive tried switching off the boiler and its done nothing,
Cheers,
Robbie.
I have a feeling the boiler may need to be set to expect the stat?
Call installer? Call Viessmann tech help?
Tony
:rolleyes: The boiler instructions do.
Only if you are using a bog standard 240V stat.
If you read the instructions for the Vitotrol there is no mention of removing the link. The diagram still shows it in place!
Cheers for the help guys, I've put the jumper back in and it's working fine. The boiler instructions are a little bit confusing, thanks again.
Robbie
Hi
I was was wondering if anyone could help with a dumb question. Our plumber just recently installed a viessmann 100 combi with a Vitotrol 100 UTA RF1 controller. He only gave me the installation instructions. Does anyone know if the vitotrol unit comes with operating instructions as well. There are a lot of options on the unit and I have no idea what it all means!
