Problems wiring up new light
Discussion in 'Electrics UK' started by Jammaestro, 11 Feb 2012.
  1. Jammaestro
    11 Feb 2012
    Thanks Received:
    Mid Glamorgan
    Country:
    When attempting to put up a new light fitting I took the old pendant fitting down checking how if was all wired up even taking a photograph before I disconnected it. I was surprised by the number of wires coming from the supply. The way it had previously been connected there was one black with a red sleeve on it connected to the live terminal 3 red connected to the loop terminal, and two black connected to the neutral terminal, and the earth with yellow/green sleeve on it connected to the earth terminal. The earth wire has 3 copper wires coming out of it. The new light fitting I was trying to put up only has a live neutral and earth connecter. I connected it up connecting the two black wires to the neutral terminal. The three earth copper wires to the earth and only the single black one with the red sleeve to the live terminal leaving the three red wires loose I taped them with insulation tape. I fixed the light fitting to the ceiling turned the electrics back on and the lights didn't work, but not now the kitchen lights don't work either. I disconnected the light fitting. It hasn't made any difference to the kitchen lights though. We're completely in the dark now downstairs and it's fair to say the mrs is non too pleased. Fortunately the upstairs lights are working. Can somebody please help me with the downstairs lighting problems. I'm getting really desperate now. Thanks
  2. fidom
    29 Apr 2008
    561
    Thanks Received:
    68
    Country:
    Croatia
    The 3 reds need to be connected together in an insulated terminal, if you have taped them up individually you are breaking the loop.
  3. Alarm
    18 Oct 2010
    8,970
    Thanks Received:
    529
    London
    Country:
    Go to the electrical part of the forum and click on the "WIKKI" there you will see a diagram for a lighting circuit.
    Turn off the circuit and make sure it is dead before you work on it.
Loading...
DIYnot News
Similar Threads
  1. hdp
    27
    948
  2. seann123
    15
    7,340
  3. nico32
    9
    2,119
  4. ramdaltd
    13
    1,005
  5. thunderhawk
    7
    813
Share This Page
