I have two Vaillant combis each ten years old in the same house, which contains a basement flat. There are constant problems with the larger unit failing to light up. It is either a 242 or 282 - it is hard to read the number. But it fails with this ignition fault quite regularly and costs a lot to fix, before failing again. It does so sometimes and not at other times. Sometimes it ceases hot water flow in the middle of a bath run. This can be resolved by turning the CH right up, but of course that uses a lot of gas in summer.
The smaller unit is also a Turbomax but I am unable to find a model number. It heats two rooms and one shower. It was operating CH perfectly but not hot water. A gas engineer came in and now it will provide neither CH nor hot water- although he swears he broke nothing - but then demanded thousands of pounds for a new installation.
I have not been able to find a trustworthy repairer in the local West London area, and those that come either refuse to quote or treat me as an idiot. One wanted to replace all the gas pipes, although they are not more than 25 years old. Vaillant itself will charge several hundred pounds just to examine either unit, without any guarantee that it will fix it within that price.
I feel that armed with a little more knowledge on the probable fault, and how difficult it might be to remedy, I might be in a better position to negotiate. Help!
