Programmable room thermostats
DP
10 Dec 2003
Glasgow
A got control to have for weather like we are having now.
Was up through the night to realise boiler was running. looked at the roomstat to see room temperature was 12 and temperature set for heat call was also 12 degrees C.
Evident the unit was operating in frost protection mode.
Blimey, if your room temp is dropping to 12 during the night you'd do better to spend some money on loft insulation than waste it on a fancy room 'stat.
Wickes are doing 4 rolls of 170mm glass wool, 8.1 m2 each roll, for just under £30 at the moment. Insulation has never been cheaper.
