I'm about to embark on a full Heating / HW system upgrade. However, there is one thing that is bothering me most. Whilst I am relatively happy at the choice of Boiler, I am unsure about the type of System I should be installing. Vented or unvented.
My current system is a vented system which seems fine. But the pressure / flow doesn't seem great.
I know that the Unvented system would give me mains pressure on the Hot Water. But My concern is whether I have sufficient flow. I have tested this (Bucket & watch method) and found the flow rate to be ~15l/min or 10l in 40sec. But, if I do the same test with another tap flowing then this drops to 12l/min or 10l in 50sec. Is this enough?
What I don't want to lose is our good shower. This is obviously supplied via a pump at the moment, which I wouldn't be able to have in a unvented system. So would my flowrate be sufficient?
Or, should I stick to what I have, a Vented system. It doesn't bother me about having tanks in the loft. Although will be looking to remove a Cold Water tank thats feeding all taps except for the kitchen! (different job).
Cheers
Cheers
