Pump Noise on Central Heating Shut Down
17 Mar 2016
Hi
Googled this as much as i can, but not found an answer. Also posted to grundfloss support, but did not receive an answer either.
So I fitted a Alpha2 Pump to replace my old pump who's bearings were going and making a hell of a noise and it was nice and silent with the added benefit of reduced electricity usage. Then added a Addy Magna Clean to protect the pump. The only place i could add it was directly infront of the pump. Everything was fine initially, however Ive noticed that when the heating switches off I get a ratt-a-tat-tat noise like a machine gun. I've cleaned the filter which had some magnatite on it and the noise went away for a while but has returned. Tank in the loft is not clean so i suspect there is a lot of magnatite floating around still and I suspect that the filter is getting gunked up.
Anyone know if the pump has a slippage clutch that would cause the noise in the event of it being driven on buy inertia in the water built up in the magnaclean?
ideas/thoughts?
Regards
D
Does your boiler have pump overrun? And if so, do you have a system bypass?
