Hi
appreciate the help please
I'm renovating a house i just bought and was knocking down a wall in my living room when a few brick came down on the elbow joint that supplied the gas fire. I've turn the gas off as its not need at present
When the new gas fire goes in i will be having it fitted professionally but need to seal up the pipe for now so i can at least use the cooker to cook lunch when im not renovating.
Basically it and the copper pipe that lead to the fire got damaged so i have removed the elbow and want to screw in and seal the black pipe that the elbow went into.
The small pipe that came out the elbow and went to the fire looks like 8mm i think but the black pipe the elbow went into via a reducing type joint at the floorboards is larger with an internal diameter that looks like half inch
What sizes do these pipes come in and how do you measure black gas pipe size.
Thank you .
Thank you .
