Radiator Key
20 Jan 2003
Quick question.
Are all radiator bleed valves / keys standard ?
Reason i ask is that every radiator in my house has a bleed valve that my key fits, except one which just has a big square hole (looks like the valve without the square bit you turn in it).
Does this mean that there is no bleed valve on this rad, or is it a different type ?
Cheers chaps !
Could it be that this rad is the one used to drain the system? I believe one rad should be slightly lower than the rest to enable the valve you mention to drain out through a hose or similar?
Sorry if I'm way off - - - - - -
:confused:
Interesting point - maybe true ?
I think that it might just have a different bleed valve type ? I'll try twisting it around and see what happens - might get a boat first though ;)
I guess the obvious way to tell is
Bleed valve at the top, drain valve at the bottom???
