Radiators hot at top, cold at bottom
29 Dec 2006
Coventry
Hello
The problem I am having is that all the downstairs radiators are hot at the top and cold at the bottom. The double radiators are also cooler on the inner than the outer rad.
The temperature difference is quite large with the top being as hot as the upstairs rads and the bottom cold to the touch.
All the rads upstairs are working normally.
There is a conventional boiler in the kitchen with a danfoss pump next to it.
I can hear/feel the pump start, stop and run when I switch it on and off.
Nothing has been done to the system prior to this fault.
Any ideas?
thanks,
Adrian
sludge in system blocking radiators
add slugde remover for a week
drain system but check if radiators have started to get warm before you drain . if this is the case just add inhibitor and away you go
if not take each rad off the wall and spray a hose in to one end of the rad hoping to clear the blockage out if this doesnt work you may need new radiators as sometime the sludge can become hard in the rads and even powerflushing wont remove this problem
i would advise a magnaclean to be installed at the same time as draining down as this will help keep the system clean and is a good filling point to add inhibitor in the future
Take the silver screw out of pump, if it is black inside, system full of crap.
