Raising cold header tank to increase hot water pressure
4 Jan 2007
I want to install a new cold water header tank in the loft (the old one is the original asbestos cement one). I'm going to build a frame so it's sat nice and high and will give good hot water pressure.
Now I understand the accepted wisdom to be that you insulate your header tank, but not underneath it, so some heat from the house will rise up through the ceiling and keep the water in the tank from freezing.
What on earth do you do if you have the tank raised? Just lag the whole thing about three times as much as normal and hope for the best?
Thanks.
You must have very poor flow for you to think that raising it will make a bug difference. :confused:
The same as if you didn't raise it.
No - you use the same amount of lagging. If you buy a reputable cistern (i.e. not from Wickes or the like) then it will come with a good quality "Byelaw 30" kit, which includes the lagging and the vent.
BTW, I can recommend Polytanks, which overcome the all-too-common ill-fitting lid problem.
