Hi Guys
I'm removing an old boiler from a hearth in my kitchen, expanding the cavity up to head height and fitting a 90cm range cooker and extractor. I have a flexible hose with bayonet fitting from my range cooker about a metre long and will need to connect this to my gas supply. The problem is my gas supply to the old cooker is located outside the hearth brickwork. The Hearth is solid to the underside so getting a pipe beneath will be hard work. Could one of you useful chaps give me some guidance on the restrictions of running the gas hose through an opening in the side of the hearth so I can connect to a gas pipe? Would I have to take out enough to be considered a void? Would this need supporting? The hearth's side is about a foot and a half deep into the wall and about a foot wide.
Thanks Guys
Thanks Guys
