Range Tribune HE
9 Nov 2010
Warwickshire
Hi, I have the above Immersion(very small) and has dropped below 1Bar,I have been informed that it best operates between 1 & 1.5Bar,it looks fairly straight forward,as in connect the flexi stainless steel pipe to the two capped connections(Hot & Cold) and open the taps,thus topping up.
Question 1. Do I turn the cold tap before the hot?
Question 2. By how much do I turn the said taps(1/4,1/2 turn etc) and seeing I cannot see any water level just Bar pressure how do I know when I have topped up enough? will the Bar pressure just rise?
Question 3. I have only been in this a brand new house 8 months,so should I have to do this so soon?
Many thanks and sorry if I come across a bit of a dim wit :oops:
The Range Tribune is the hot water storage cylinder, this operates at a higher than 1bar pressure but will not be of any concern at thish stage.
1 to 1·5 is the operating pressure of the heating system. Yes, connect the flexi pipe and turn on the taps.
they are not hot and cold, one is the main in and the other is the inlet to heating, turn on the one that is on the pipe going into the cylinder after the other one.
you will hear the water running through the pipes, watch the gauge until it reads about 1·25.
Quite usual to need topping up after a short period as the air that was trapped in the system may have vented through an air vent.
