Re: Rendering a cellar
28 Sep 2007
Yorkshire
Hi, Could anyone help me please, I want to render a sand stone internal cellar wall (12inch thick)can you or do you need to use a stabilising solution (yes there is efflorescence) and then a mortar based water proofer.
I use the cellar as a woodworking workshop, it is well ventilated there is an input fan and a blower fan...
The all the walls were previously coated with some sort of bitumen and then painted (before us), and this is the only wall with a problem, it has blown in some places 30% ish, which I have stripped back to stone with a large wire cup brush on my angle grinder, What would be the best way to proceed,
Any advice would be helpful. Thank you!!
Having removed all traces of bitumen, you need to firstly treat the surface with an "anti-sulphate" solution to neutralise the groundwater chlorides. Typically you would treat with "anti-sulphate" dilute 50:50 with water and the following morning before applying a polymer modified render, you apply the "anti-sulphate" neat by spray or brush. This forms the basis of any effective cementitious under ground waterproofing system.
