There's no problem in connecting a switch which is physically downstairs to a light (landing) which is supplied by the 'upstairs lighting circuit'. The important thing, as explained by eric, is that both the neutral and live for the landing light must come from the upstairs lighting circuit.Was going to take a supply from upstairs down to master downstairs for landing light upstairs so the breaker turns the landing off on the up lights as its upstairs so is that safe taking a supply from upstairs to a switch downstairs ?
That's always going to be a potential hazard if you want 2-way switching od a landing (or hall) light (i.e. a switch both downstairs and upstairs for the light - which is totally 'standard') and have two or more lighting circuits. If you did it the other way around, and supplied L & N for the landing light from the downstairs lighting circuit, then, although the downstairs switch would be 'safe' (totally dead when downstairs lighting circuit was switched off), the upstairs switch would then be live even if the 'upstairs lighting' was switched off. For this reason, one has to be very careful when working on lighting circuits which do, or may, have cross-floor two-way switching. If there is any doubt, the only safe approach is is to turn of all lighting circuits.Yep was going to take the live and neutral the light upstairs then take the split live to the switch downstairs to the master just worried that it's against regs as if someone turned the downlights off on breaker board that switch would still be live downstairs ??
I must say that I hadn't considered that possible interpretation of what the OP has said. As you say/imply, there is no need to (and probably not enough cores in the cable to) take a neutral (from upstairs circuit) down to the downstairs switch - just the usual three cores ('strappers') between the two switches. I took the OP's concern to relate to the fact that this would involve a connection to the upstairs circuit L being physically present in the downstairs switch - which, as I've said, is an inevitable consequence of 2-way switching (when there are multiple lighting circuits), and something one needs to be very careful about when working on lighting circuits.Just so I'm clear what you intend to do because the terminology you are using is confusing. ... Because it does sound as if you are thinking about using the landing ceiling rose's live and neutral to the landing switch and then linking to the downstairs switch - in other words you are taking the upstairs neutral downstairs.. While you can do this I'm not sure why you are considering doing it.
Ah, I'm not as 'investigative as you' - I tend to take each thread in isolation, on it's own apparent merits. However, now that you point out that that other thread is also his, I agree that you could be right.JohnW2, having now read his other post which appears to cover the same subject with the 3 day 'electrician' I'm not convinced he knows what he is doing full stop.
This is getting much more complicated. Although it's discussed in the other thread (which i didn't initially connect with this one), your question which started this thread said nothing about masters and slaves - hence the fairly simplistic answers you got!Taking a live/neutral from the junction box (coming from fuse board) to the lights then taking the split live down to the bottom switch which is a master which has to be as its a 2 way for a single light at bottom then fetching a 3 core back up to the slave which will work the landing 2way ...
If it's any consolation, I'm not an electrician, so I have no axe to grind.... and the proper advice would be get an electrician I no this but he don't seem to no how the electronic switching works and the simple fact you can't put a mains live into a slave ! I do appreciate everyone's help but no that some electricians don't like giving advice because it's there livelyhood which is fair enough
Right I'm trying really hard to understand what you are saying here but I don't know what you are talking about when you say split live- do you mean 'switched live' or permanent live?Taking a live/neutral from the junction box (coming from fuse board) to the lights then taking the split live down to the bottom switch which is a master which has to be as its a 2 way for a single light at bottom then fetching a 3 core back up to the slave which will work the landing 2way and the proper advice would be get an electrician I no this but he don't seem to no how the electronic switching works and the simple fact you can't put a mains live into a slave ! I do appreciate everyone's help but no that some electricians don't like giving advice because it's there livelyhood which is fair enough
