Replacing 3 Radiators £500
27 Nov 2010
London
Hi
I have been quoted £500 to replace 3 radiators (including the radiators) and just wanted to know if this a good price.
Im changing from:
a. 1200 x 500 double to a 1400 x 600 double
b. 900 x 500 double to a 1400 x 600 double
c. 1200 x 500 single to a 1200 x 600 double
all the rads will be placed in the same position
Is this quote any good?
Any less in London, and his name will probably be Jerzy Bolovski and the receipt will be in Polish.
yes sounds fair, just make sure some form of corrosion inhibitor is added on the final fill or you will pay for it in the long run
for london its very cheap.make sure you get decent radiators fitted.
I would usually quote about £525 plus anything not included in the materials quote above like drayton TRV4s which I would expect to fit to all new radiators.
Tony
That's an outragous price.... He should be paying you for allowing him to fit them remembering to doff his cap at you as he goes...
For that price I bet the cowboy is going to mr central heating for the cr$p radiators. Dont worry about the inhibitor, he will probably **** in the header tank for free!
thanks everyone for your help.
how would i know before hand if the rads he will use will be any good?
well it seems yoy want hotter rooms due to large radiator sizes.
dont forget your boiler could be limited to a certain output but maybe not.
sometimes a system balance can increase heat output in radiators but if radiators undersized originally your best off with new radiators.
what boiler do you have ?.
stelrad radiators are ok but even a badly fitted decent radiator will suffer if installed incorrectly.
go to your local central heating/plumbers merchants (independent) not a big shed and tell staff what you want done with your measurements and ask if a local guy could be reccomended..
works for me.
works for me.
I have a vaillant turbomax compact
how do i know if a rad has been fitted badly or not?
I just paid £140 for a Centre Brand 450mm x 2000mm Double convector about the biggest they do in their own range.
There is a fair cost in materials there prob around £250 or so
...go to your local central heating/plumbers merchants (independent) not a big shed and tell staff what you want done with your measurements and ask if a local guy could be reccomended..
works for me.
That is most certainly not a good method as there is a conflict of interest.
For recommendations you should ask friends, neighbours or colleagues, not a guy who has a vested interest in sending his mate.
