My mains water supply (bungalow, concrete floors) enters the house through the bathroom floor. The bungalow is 1960's and the main appears to be the old 1/2" copper covered in denso tape where it rises from the concrete. The isolation valve is old/stiff and does not shut off completely so I want to replace in the near future. I suspect the copper pipe is a thick walled type.
Questions:
I think you need a special compression fitting for soft thick wall copper - I do not think you can simply use a standard olive etc. ?
How do I go from the old 1/2" pipe to a new 15mm stop valve?
All advice welcome - thanks
Questions:
