replacing wc ball valve and installing an isolator
25 Dec 2007
Our toilet has a flexi connecting the inlet to a pipe coming out of the wall.
There is no isolation valve and I would like to install one when i replace the ballvalve. Is there any flexipipe availabkle that has an inbuilt compression isolation valve so that i can just carry out a straight swap?
Or is it best to attach a compression fitting between existing flexi and wc cistern water inlet?
any advice and link to parts needed for this job would be extremely appreciated.
thks, i take it the compression fitting end attaches to the wc cistern inlet or is it the other end?
compression end to the pipe 1/2" fitting to the cistern.
it will only go one way.
