I am looking to extend and retrofit UFH to my 1830s cottage. The two rooms which form part of the existing house are the hall and the dining room. The hall is within the original part of the house and the dining room was bolted on in the 90's. My concern is what construction to use in the hall. There is a small amount of damp in one corner around the fireplace, but the rest is damp free. If I didn't have any advice, I'd look to excavate it all, type 1, sand blinding, DPM, insulation and screed and UFH. The DPM would need to be tied in the existing stone work (400mm thick walls) by cutting a 1m slot and installing DPC and grouting back up. (for the exterior wall only). Is there a better way of undertaking such a task? Having read a few other posts, a few recommended a suspended timber floor but the posts were aimed at ridding damp issues, plus I'm not sure I like a timber floor construction with quarry tiles above.
I am unsure of the present floor construction and won't find out until I come to undertake it.
Also, will UFH be an issue with solid stone walls? Is it worth insulating the wall on the inside with insulated plasterboard? Space isn't an issue.
