Roof access via carport
6 Jan 2012
Essex
Hi All
I am fitting eaves felt trays and need to access the roof above the carport. The carport roof is polycarbonate. Can I use some 18mm OSB as a crawler board or do I need something stronger.
The carport is around 5m long with 3 struts across so a crawler board would only have 2 struts to support it at any one time ( as well as some support from the poly roof).
I would rather not remove the polycarbonate.
Jono
I was hoping it wasn't risky. I probably won't do it as don't want to end up worse off if it all goes wrong and I end up needing a new carport (and car as I would most likely forget to move it).
I have now asked for some quotes for new felt and trays for the bottom bit of roof.
Jono
