i will drop a cable/2wire from the new DRT1 to pick up the live in the terminal block and via the stat to the correct actuator...which will be for the kitchen floor circuit
When you say two-wire - you must use 2core+earth (or 3core flex) even though the earth may not be required for the thermostat.
**thanks..i wondered about that...i guess i should just block the earths or cut them back to the grey
there are 3 actuators and 3 room circuits and two stats at present!!
**QUITE!!! the installers ran out of ways on the terminal block and wired two room circuits together...the problem then was....they used the living room stat to control the kitchen and wired the kitchen and dining room together on the dining room stat....that is why i have reconnected them properly and fitted the necessary kitchen stat
the existing cable from the other DRT1's i have ascertained are grey pvc with a brown and a black wire to supply/cut the live to the actuator via the DRT1's operation
Brown, black and grey are the colours of 3core+E which is why I said there might be a grey you have not noticed.
**sorry i take your point now...i guess the grey is folded back in the stud wall and only the black and brown brought through to the terminal block
i can see cable available in my local depot which is grey pvc but the wires are blue and brown..
That is the colour of 2core+E.
**cheers
i am asking if there is a colour code i should be following....the brown will and is the live
the existing blacks are the feed to the other two actuators
These blacks (or the blue) should be sleeved brown to signify they are line(live) conductors.
**brillant point ..one i hadnt condsidered by you are right...brown it is!!
