Rover 45 TD Power steering pump leak
17 Apr 2007
Is the pump easy to remove to put a new seal in?
Has a slight leak for a while and seems to be the area of the pump.
Would it be easier for you to fit a pump from a breaker, or ebay?
Much less hassle......do check the pipe from the reservoir though, they do tend to weep from there.
John :)
Thanks for that.
I pressure washed around the power steering to make it easier to see.
I see what you mean about a replacement pump being easier.
As yet haven't seen any drips - strange!
having built the pumps from factory ( read further development etc)
No
The leak is from the rear seal in the ally cover
there is a coupling on the rear that drives the water pump the does not part company with the shaft without destroying it.
then you need to get hold of a seal
