Salamander shower/house pump
11 Apr 2006
Berkshire
I have a Salamander twin pump that pressurises the entire house every time a hot or cold tap is turned on. It even comes on when you flush the loo. It's so noisy we've had it switched off for a couple of months now. The water pressure with the pump switched off is fairly pathetic (all gravity fed from the loft) but I've started to wonder if the pump itself might cause a flow restriction. Might I benefit from completely removing the pump?
What pressure do all your taps etc require? If you need 1-3 bar, then you'll need a pump, unless your loft is 80ft high. There are better, quieter pumps on the market, though that is one of their better models. The problem you'll have is the plumbers will probably have put 15mm or 22mm at best pipe everywhere and some of your taps may even be 8 or 10mm.
You'd do better replacing the planks its sat on with a nice thick bit of dense memory foam. Really does help reduce the vibration noise.
Also plug it into a timer so that it is only working between 6.30 am to 10.30 pm. That way when you go to the toilet a 3am it won't wake the family.
Andy
Thanks guys. I've no idea what pressure I require in terms of the pipework and tap specs. I think I'll need to spend more time on this looking into what I already have then.
Nice idea re: the timer switch - that could be a quick win in the short term.
