Saniflow unit not pumping
Discussion in 'Plumbing and Central Heating' started by Psyclist, 4 Apr 2012.
  1. Psyclist
    15 Jun 2010
    171
    Thanks Received:
    5
    Northumberland
    Country:
    I've got a Sanivite 3 which is less than 1 year old, but after a phase failure yesterday it has stopped pumping.
    I've dismantled the unit and cleaned everything, checked the fuse in the spur and that's fine, but I cannot get it to do anything.
    Having removed the pump unit from inside the case, the electric side is obviously sealed up so I don't want to go poking around in there, but where is the switch located in these things and how can I test it?
    Kristian
    *UPDATE* When tipped upside down, the pump fires up, but I can fill the case to the brim and it does nothing.
  2. Agile
    26 Jun 2004
    61,294
    Thanks Received:
    4,285
    London
    Country:
    You seem to have done a lot to it without understanding how they work!
    They have a sensitive pressure switch connected to the tank by a thin tube.
    Tube and connections need to be clear and dry!
    Tony
  3. Psyclist
    15 Jun 2010
    171
    Thanks Received:
    5
    Northumberland
    Country:
    No thin tube. It was just a pressure switch at the bottom of the actual pump unit. The microswitch had failed inside.
    All I did was clean it up and lift it out to inspect. I didn't want to break the seals and open it up without further knowledge so I contacted a Sani-flo engineer who turned up, pulled it apart and put a new switch in, silicone sealed it and put it back in the case and it worked straight away.
    Job done.
  4. Agile
    26 Jun 2004
    61,294
    Thanks Received:
    4,285
    London
    Country:
    That was an expensive solution.
    With my guidance you could have bought the switch for about £20 and fitted it yourself!
    Tony
  5. Psyclist
    15 Jun 2010
    171
    Thanks Received:
    5
    Northumberland
    Country:
    I work in a hotel with a large wedding party in tonight and that was the drainage from the bar so it absolutely had to be up and running by close of play today so I had no choice but to call an engineer if I didn't have it fixed by lunchtime.
  6. Agile
    26 Jun 2004
    61,294
    Thanks Received:
    4,285
    London
    Country:
    Never seen anyone in Hotel Babylon having to mend the plumbing!
    I doubt Michael could do any pumbing anyway.
    Tony
  7. middlesbrough
    14 May 2009
    4,794
    Thanks Received:
    487
    Middlesbrough
    Country:
    Bassil faulty did fookall either ........youd put him to shame psyclist !
    Know wonder they only made 12 episodes.......couldnt get the staff ! ;)
  8. Agile
    26 Jun 2004
    61,294
    Thanks Received:
    4,285
    London
    Country:
    I thought Hotel Babalon was brilliant.
    But just like Ladies' No 1 they scheduled it at an off peak time which was totally wrong for an expensive production!
    Tony
  9. 75pete
    9 Apr 2008
    501
    Thanks Received:
    44
    London
    Country:
    Tony, would it be possible for you to add the information that you said you could have saved Psyclist lots of £, to the FAQ list?
    Pete
  10. HERTSDRAINAGE2010
    9 Apr 2010
    6,465
    Thanks Received:
    905
    Hertfordshire
    Country:
    He can, but it will cost £84 + vat.
    Andy
  11. 75pete
    9 Apr 2008
    501
    Thanks Received:
    44
    London
    Country:
    In the post!
    Pete
  12. Agile
    26 Jun 2004
    61,294
    Thanks Received:
    4,285
    London
    Country:
    There is no specification to put in the FAQ.
    In this case I had advised the OP about the pressure switch and in a home situation he would have been able to check and replace it.
    If he had properly advised that its in a bar at a hotel then I might have said something different.
    He was lucky to get someone out the same day. One of my clients was told he would need to wait a week!
    Tony
Loading...
Share This Page
