Satchwell TLX 2259 Thermostat
7 Apr 2013
Hertfordshire
Would appreciate some advice. Have attempted to replace my thermostat with a different type (Honeywell THR840DUK). The new one whem fitted kept blowing the fuse.
I have re-instated the Satchwell wiring as it was when I removed;
Terminal 1 - Blue
Terminal 3 - Brown
Terminal 4 - Green/Yellow
Back Plate - Bare Earth Wire
When I turn the thermostat up to kick-in the boiler/heathing the fuse keeps blowing.
Any assistance would be much appreciated.
Kind Regards,
If you have wired it exactly as before then it should be fine. The 2259 is -
Terminal 1 - Switched live
Terminal 3 - Live
Terminal 4 - Neutral
Which, at a guess with your colours would be -
Terminal 1 - Green/Yellow (which is a no no)
Terminal 3 - Brown
Terminal 4 - Blue
Just to stress, this is a guess and the colours could be used any way round. Would need to test with a multimeter to confirm.
The neutral is not required for the new stat.
