I recently moved house and in the corner of the front and back bedrooms the paint is flaking off the walls in both in a small patch. It appears that the paint was applied directly to the bare plaster as this is visible beneath the paint. The house is timber framed front and back and this is happening where the timber frame meets the external brick wall. There is no evidence of damp nor any found in the full survey.
I am redecorating and was a bit confused as to how best prepare the bare plaster prior to painting as I will clear the paint off these areas as it literally falls off! For the unaffected areas I intend to paint directly over the existing paint after washing down the walls.
Should I use a primer/sealant or a water down emulsion mix? I plan to use Crown emulsion.
New to this so any help/tips greatly appreciated.
