I've looked through the threads here and note the recommended method of blocks and bearers.
My shed will be 2.9m wide and 2.1m deep. The joists run in the direction of the longest dimension and are about 40cm apart. So the bearers will be 2.1m long, would a block at each end and one in the middle be enough support for each? How far apart should they be, if we had 4 bearers they would be about 1m apart, is that too much?
Thanks in advance for your help.
