I've built one of these shed/cabin things. I'm replacing the supplied plexi windows with some double glazing.
The DG units will be toughened - manufacturer reckons 4/10/4 will do the trick.
The doors and window are recessed from the inside, approx 20mm. There is no beading etc to deal with on the outside.
So, I took the measurements of the plexi panels. They are probably around 2mm smaller than the opening all round.
How much should I reduce the measurements for DG units? 5mm sound about right?
I was thinking about bedding the units in with neutral cure sealant, and then some neat beading on the inside to cover the edges of the DG unit? Or should I use a butyl glazing tape?
I've done a search though and I see mentions of drainage/packers etc needed for timber framed windows. Will these apply to me with my DG units fitted from the inside?
Cheers!
Cheers!
