Folks,
Can some one give some detail and help me out??
I have swapped out old pump with this Grundfos one. Have literally reconnected the water pipes as per the previous pump and plugged in and no joy with water although the pump is running.
Problem:
Plug the pump in and it runs continuously with out the shower being on and no water coming through.
Switch the shower on and still no water.
The pump has a LV transformer which is wired directly to the pump and then has a mains connection. There are 2 wires to connect to the pump but no indication asto which way round. Could this be a problem??
The manual says to connect to a 230v switched spur. Is this different to putting a plug on and plugging into a normal mains socket or is this a completetly different connection?
Below is a pic of the hw tank and I assume an electrical supply (white box)
This photo is where the previous pump was plugged in. The unit above is the CH / HW Controller. One wire comes out and goes to the socket and the other wire that goes off to the right ends up inthe white box in the photo above.
Problem:
