I need to size a system for my local rugby club which currently has 2, very ancient, 280 litre Andrews water heaters supplying 11 showers and 3 basins.
The most showers I've had to supply water for in the past is 5 so any advice would be welcome.
My first thoughts were to install an accumulator in conjunction with 2 x 300 litre Megaflows with a 28mm cold feed to the cylinder although the client has been told they would need three accumulators to provide adequate flow. I haven't fitted an accumulator before but thought this sounded a bit excessive?
Also, can I install 2 Megalfows in sequence or should they be fitted independently and then supply half the outlets each?
Cheers, Ben
Cheers, Ben
