SL8 Alarm (8SP 402 SL8 G3 Panel with remote LED Keypad)
16 Sep 2006
Fife
Hi
I have this system in a flat I rent out. Tenant has just advised it's not working. When they enter the 4 digit code they're not hearing the 20-30 sec beeping 'arming/setting' sounds and the alarm doesn't appear to be setting. The sensors still go red when walked in-front of but no alarm sounds.
On the keypad all the lights down the left side (Zone 1 - Zone 8, Tamper, Attack) are not lit. The keys with numbers 0-9 are lit and the keys underneath aren't lit (Chime, Omit, Reset, Prog, Set.) Keypad same as this:
http://www.alertelectrical.com/uploads/prod/11_343_e.jpg
I'm aware there are engineering codes etc that can be entered to test/reset the system, can anyone advise as to the easiest way to do this? I'd like to try things myself first prior to calling anyone out in case it can be resolved by pressing a few keys ;)
Do keys bleep when pressed ? Have they had a power cut ? When did it last have a battery ? .......
i think the keys beep when pressed. not sure re power cut. i've had the place since 2008 and defo no battery changed in that time. do you reckon changing the battery is a good thing to try re: rectifying the issue?
I won't be able to see it myself until after xmas and new year now.
Sometimes when the battery is not up to scratch and a minor power cut happens , it can stall the panel , it may be a down power and new battery , but it may be something else !
