sloping firedoors to fit into loft conversion doorways
21 Jan 2011
hi
can anyone help me find a solution to ? bespoke fire rated doors , 30minute , which can either be cut off on a slope ie top corner cutaway , or made to measure , and that will then fit into a doorway in the loft conversion that has part of the top of the door sloping into the eave / slope of the roof. we couldnt bring the doorway openings further into the centre of the roofspace because of large chimney breasts.we will need to fit a door on each side of a landing area - sorry - not really sure how to describe it any better.
thanks very much
minty123
if you cut out that much from a fire door then the door is comprimised,you can get the manufacturer to make the doors to your requirements.
thanks - i will have a look and find a manufacturer who is prepared to make bespoke firedoors - guess ive no other choice - sounds like it may be expensive !
You cannot get manufacturers to make non standard fire doors as each fire door as it leaves the factory needs to be certified and therefore tested as a fire door, this would be cost prohibitive for individual doors. The only option is to use a specific fire door blank which can be cut to suit on site. Note these are not standard fire doors that are trimmed to suit but start off as 8’ x 4’ fire rated panels that remain certified even when cut down to any shape provided the lippings are replaced. Eg http://www.wood-floor.co.uk/internaldoors/firedoors/firedoor-blanks.html
