Hi all,
I'm in the process of digging out some 30 year old 8' leylandii, removing an old wood fence and replacing it with larchlap panels and concrete posts. Back-breaking!
8' posts, 2' hole dug narrow and deep, then using postcrete. Postcrete has been going in dry (~1.5 bags per hole), tamped down well, then added water. Few questions:
1. How can I be sure that the water has penetrated the whole hole (pun intended!), the full 2 feet? and not left some dry mix at the bottom of the hole.
2. Is it possible to add too much water, and adversely affect the postcrete? I've added most of a bucket, which has left a good covering of water over the surface of the postcrete. When I return later, the first inch or so of concrete has not gone off (it's soft) - but under this it seems fine (and the posts seem solid enough). This top layer never goes off.
Thanks in advance...
Andy
Andy
