Hi
I was wondering if someone could help me ?
There was a small drip coming from spindle on the water stop cock below the sink in my house. I understand that this is a common problem.
I backed off the gland nut and wrapped some PTFE tape around the spindle tightly, pushed this down the spindle with a screwdriver and then tightened up the gland nut. I repeated this 3 times. I did not remove the original gland packing material.
The leak initially stopped, but what I was wondering was that as I opened and closed the stop tap, it became easier to do, which suggested that the PTFE tape was wearing as the spindle rotated around. After a few times the drip re-started.
I found that I could tighten up the gland nut each time it became easier to open and close the tap, which I assume each time compressed the PTFE tape.
Is the PTFE tape only an emergency repair or am I missing something ?
Many thanks in advance.
