Hi
Most questions here seem to be about boilers, so hope it is OK to ask about non central heating realted stuff.
I have a Caple Atlanta monobloc single lever mixer tap, with a lift and swivel mechanism (up/down for flow, left/right for hot/cold). The left/right movement is OK, but the up/down movement is very sticky - I can get the tap to give me minimal flow, and then it jerks up to full flow - given me a fair few wet trouser moments. It seem too sticky to get it to move smoothly from one extreme to the other.
Is there any way I can loosen up the movement, or is there a problem in the ceramic valve? I've seen these online and they seem to be about £15, so not too much, but I don't want to replace it if that's not the source of the problem. I assume I can't add lube without it getting into the water flow?
Any advice appreciated
Col
Col
