Still Damp or condensation...
8 Oct 2012
Stirlingshire
Hi,looking for a 2nd opinion....recently bought a 4 in a block type flat with my partner, on survey it was found that it had high damp readings mostly to one side of the property (were the upstairs stair way is) also some flooring and timber was rotting. A surveyor quoted to repair works which involved replacing rotting timber joists and putting up a damp proof membrane also replacing the plaster board a metre high. Well my partner is a joiner and has a lot of experience with building houses/extensions, so we did the work ourselves.
So far each bedroom we have lifted all the floor boards replaced rotting joists. We found the solum tar was broken up so cleaned this all up and put membrane down and concreted this, then painted the brick work with bitumen paint and replaced flooring. The back wall of the room we strapped it out to create a ventilated area and put membrane on the back of the new plaster board before we put this up.
Well after all this work we then went to decorate. In the main bedroom we have built a wardrobe the full width of the room, although this has not got any doors on it yet it has all clothes etc in it. Went to move drawers that were in it to decorate to find a bit of mould of the back were a chest of drawers was sitting :-/ well we know that this can happen because of poor ventilation but it hasnt had any doors on the wardrobes so I was a bit concerned.
We bought a moisture metre but not sure this was helpful as it doesnt tell you what the readings actually mean and the readings seemed to jump about a lot! was coming up the same for most of the room although at certain bits slightly higher readings, more lower down on the back wall. We cut a hole in the plaster board in the wardrobe and had a feel and the brick with the bitumen paint was quite wet although this is on the inside could this be condensation from the inside? When we replaced the joist we left a slight gap so there is no wood bridging for any damp to get through from outside.
We cant think of anything else that could or can be done if there is still a problem as we strapped out the wall and made sure the ventilation brick vents were cleared.
Your post is really, really hard to read due to the lack of punctuation so don't expect too many replies!
Is the room well ventillated and do you dry clothes in there? What is on teh other side of that wall?
It does sound more like condensation to me.
The room isnt used for drying clothes in and the other side of the wall is the outside of the house.
The wet that we can feel is as if its running down the inside wall over the bitumen paint so thats why Im thinking it is more likely condensation as the bitumen paint is to stop the wet coming through from the outside. Not that theres water running but does feel damp to touch.
The way you describe it does sound like condensation, even though you don't dry clothes there.
It's not generally a good idea to coat the walls with bitumen paint; any water vapour condensing on it can't be absorbed by the bitumen and it will run down the wall. The studwork you appear to have put up may make matters worse because it hinders ventilation.
From your description, it's still not easy to work out what's going on; perhaps some pics would help.
