Strengthen door hinge the area where the screw goes into the
20 Jul 2008
Lincolnshire
Strengthen door hinge the area where the screw goes into the door.
Hi the holes that i put screws in are worn i have pushed a matchstick in in the past i thought about putting glue to get a better hold. Any suggestions would be welcome.
Mark
or drill out to 9mm and hammer and glue 10mm dowel in,leave to dry then drill and fix new screws
A matchstick (or two), or similar slices of timber wedged in and glued, will actually be stronger than the timber it replaced
Or a wider screw?
Don't make this job more complicated than it needs to be!
Found this little site the other week. Personally I think its very, very amateurish but there is an article on internal door frame refurbishment. It may be of help but as I say very amateurish site.
