Hi all, I have asked hubby to build me 2 summerhouses (to avoid B Regs) in the garden 5x6m & 7x4, so far so good but tbh I am rather anxious
He has done foundations @700mm & filled to top with concrete (over ordered, bad on my part) Concrete base has been done 150mm over hardcore base (150mm binded with sand 200mm, then DPM & 25mm insulation) and he's now doing single skin block work, but I swear it looks pist/****ed??
So i have several queries....Is single skin ok? Doe's he need to put piers in as I have seen in over similar posts than brick reinforcing coil will cut the need for piers, if so would you use this on each course?? My main issue is keepin cost low as so far it's cost over 2k & looks to be over my budget of 5k once the roof is on & it's finished inside Are there any techniques to starting the horizontal plumb line? I think putting nails in is moving the two end/corner blocks.
I hope some one can reassure me If you have any other tips/ advice please feel free to offer them (over than get a builder to do it)
