Hi, my daughter was playing with some superglue on my good kitchen table and the enevitable happened. Super glue now stuck onto table, how do I remove without damaging the woodwork ?
nail varnish remover will remove superglue
if the wood is oiled at all then as said it may chip off
rather than scrape try and get a sharp chisel or blade with the cutting edge flush to the surface so it lifts the superglue rather than dig in to the surface
