Switch live PIR
6 Apr 2010
Hull
Morning all
Sill question on its way
I need a outdoor light with PIR and with a switched live so light can be on constant. but when looking online nothing seem to tell me if it has a switched live on it. So does anyone no how to identify if it has one or not.
otherwise i'll have to go to the shops and start opening the boxes to fine what i need
Cheers
Do you mean you want to put voltage onto the switched live contact of the PIR, eg have a wall switch that will override the PIR?
If so the SPECRA range from Friedland have this feature, you can view the instruction (wiring diagram) on this website.
http://www.tlc-direct.co.uk/Products/SS6016.html
Ideally in addition to the over ride switch you should have an additional switch to switch off the lights completley.
If you don't have the switching arrangement in place then most PIRs have a feature when you turn the switch on and off a few times to over ride the PIR
yes looking to override the PIR from wall switch but looking for a all in one
light and PIR
PIRs have a feature when you turn the switch on and off a few times to over ride the PIR but when you need to turn them off you carnt turn the supply back on till its day light again (this is the problem with the light i have now )
you cant turn the supply back on till its day light again
That can't be right. What exactly do you mean?
How does it know it's dark when the power is off?
Normally when turned back on the light will stay on for as long as you have the time set before reverting to sensor operation.
are you sure? all PIR lights I have seen override the pir by switching off then in within (usually) 3 seconds, to reset to normal detection, switch off for at lease 30 seconds then on again.
The light will come back on when you switch it back on initially, but will go out after the normal "on" time
Providing the Feed and the switchlive are on the same circuit, i cannot see why you cant put the switchlive in the pir/ output lampholder terminal, although it will also bypass the photocell.
Or have i missed something :confused:
Yes that will work good idea but will probably not comply with manufactures Fit in instructions
Mmmmmm seem to have got a lot of answers but no answer to the first main question so will go to the shops and start opening boxes
Thanks for the help gentelmen
Before you start opening boxes, read what's on the outside of them. If they indicate that they offer the facility of having the PIR control additional lights (as well as the integral one), they must have a switched live terminal available.
Kind Regards, John
yes i know but have never found a box that has any indication on the box that is has a live feed and a switched live feed
this is my question how can you tell without opening the box
