swollen front door - what waterproofing to use?
30 Dec 2016
front door seems to be swelling - I used a plane to shave a bit off but sadly rain came from a certain direction.
whats a good product to waterproof it? saw ronseal at BnQ?
does it need to dry out first?
its getting really hard to open :eek:
Yacht varnish it when the weather gets better. It'll shrink back in the summer, and you may then find it's too loose. Make sure you paint every single part of it though; living a few yards from the sea, I even do under the hinges, and inside the door lock as well.
Which edge or edges are beginning to swell?
When external doors begin to swell its often the end of the road for them - esp. those "hardwood" Carolina and Kentucky types that were all the rage a few years ago.
Very few external doors with a "varnish" or paint finish are correctly (and painstakingly) detailed.
not sure what type of door it is. will take a pic later
seems like its swelling on all the edges! top and side especially!
think the guttering above was broken by roofer doing quote - so its dripping and splattering the door ☹
I'd trim the minimum of material off with a plane ( to prevent excess gaps in the summer) and for a coating I'd use one of the Sadolin products.
You must coat both sides of the door to prevent bowing and it's a good move to remove it to treat the underside edge and weather board.
John :)
